Leaking radiator...oh boy. Need help!
Old Oct 8, 2009 | 02:16 PM
xlionheartx's Avatar
I pull home last night to reveal my car overheated. Steam comes from under my hood. Radiator is empty...so today I poor more fluid in...and it immedietly starts leaking. Quite a bit, From near the front of the engine (Along where the belt is.)
Anyone know whats going on?
EDIT: 1992 Camaro RS 305, btw.
Old Oct 8, 2009 | 03:01 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Leaking radiator...oh boy. Need help!
Sounds like 1 of 2 thinks
1. your radiator is toast
2. your water pump is shot
3.one of your hoses blew and you should replace both
Find out where exactly is it leaking from and you'll figure out if you need to replace 1, 2 or 3.
Old Oct 8, 2009 | 05:36 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
if it's your water pump it will probably be leaking right behind the pulley
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
