Can't seem to pass my smog
Old Oct 11, 2009 | 12:55 AM
Hooyah's Avatar
I have recently taken out the egr and cleaned it, and made sure the part is still functional. Well so far everything works fine but i have not passed my smog what other methods should i consider looking into in order to pass? 89 iroc/ california
Old Oct 11, 2009 | 08:54 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Can't seem to pass my smog
What are the numbers? How old is the O2 sensor and catalytic converter?
Does it run well?
Old Oct 12, 2009 | 02:37 AM
Hooyah's Avatar
Runs great but the smog went bad, the only thing that did not pass was the No it should be at 772 but mine was at 1667? I haven't looked at the o2 sensor, dont even know where to search but i will find out soon enough. Any other input would be greatly appreciated. Ohh by the way I think the cat is four years old.
Old Oct 12, 2009 | 09:22 AM
jv9999's Avatar
Engine: 5.7L/350
High NoX points to the EGR. It may be not opening or the ports are clogged with carbon.
Old Oct 12, 2009 | 06:11 PM
Hooyah's Avatar
I tested the EGR and it was ok. But ill take a look at it again.
Old Oct 12, 2009 | 06:26 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
You can get a vacuum tester for the EGR, also do you have any upgrades/mods?
Old Oct 13, 2009 | 03:04 AM
Hooyah's Avatar
No extra mods, still hunting down the problem any advice?
jaridjohn
Oct 5, 2015 07:01 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
