What is the valve on air tubes?
Car: 1988 Firebird Formula WS6
Engine: 305 tpi lb9
Transmission: 5 speed
Axle/Gears: 3.45
I was wondering if the valve on the air tubes for the exhaust manifold is a one way check valve. If i romove the hoses to them will I have an exhaust leak?
Engine: 305 tpi lb9
Axle/Gears: 3.45
Re: What is the valve on air tubes?
I want to buy hooker 2055 with y pipe since it is the only one i can find that is quality with a 3 inch y pipe. The problem is my air pump is shot and the new headers have the tubes. Do i have to seal them shut? im not a good welder either.
1992 Trans Am
May 10, 2023 07:19 PM
Street Lethal
Aug 12, 2015 11:33 AM
