ZZ4 head swap, head bolt part numbers?
Old Oct 19, 2009 | 10:55 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Hey guys the time has come for me to FINALLY get the heads and cam put in this beast due to the fact I'm not so scared to tune it anymore so here's my next question.
I want to get new head bolts before I swap over but I can't seem to find the right part number for the bolt kit that goes with these heads. I know they are different from regular head bolts due to they need a specific washer on them to not tear up the heads. Or.... can I get away with using my stock ones and put the proper washers underneath them? any help would be great because I'd like to get started this weekend. HELP!!!!!!! lol
Old Oct 19, 2009 | 11:05 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: ZZ4 head swap, head bolt part numbers?
http://www.competitionproducts.com/p...?number=HB8201 are much cheaper, and proven up to 600 hp.
Old Oct 19, 2009 | 11:54 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
GM part numbers:
12338045 long bolt w/washer (14 required)
14088946 medium bolt w/washer (4 required)
14088947 short bolt w/washer (16 required)
These bolts are longer overall the same as the thickness of the washer. So the thread engagement is the same as regular bolts and no washer.
There is thread sealant already on the threads.
After pricing these bolts it would be worthwhile checking into ARP bolts. IIRC they were on the pricey side even back in '92
RBob.
Old Nov 1, 2009 | 06:01 PM
I found a whole bolt kit with those parts number for pretty cheap.
GM#12495499 $26.00 plus shipping from gmpartsdirect. They cross referance to different numbers but they are the same.
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
armybyrd
Aug 10, 2015 09:23 PM
1nastygta
Aug 8, 2015 07:38 PM
