BUILDING A 383 LT1
Old Oct 29, 2009 | 08:07 PM
88LT1Drop's Avatar
Car: 1988 Camaro Conv.
Engine: 96 LT1
Axle/Gears: 3:73's
BUILDING A 383 LT1
what parts and **** should i get to do this swap? what brand and all that kind of stuff? did all the **** on my car swaped in the 1996 lt1 and t56, got it running and driving but when it comes to getting a engine done out dont know to much jsut the basics. getting it all machined and ported, polished blahblahblah from a shop but what parts should i put on it? what brand? forged or cast? wat kind of springs? lifters?... i wana be pushing out 420 - 450 horses and still have a good running street car that will eat mustangs and turbo'd imports. and i dont know what i want in a cam. ALSO i am on a budget. After putting in the motor and getting it all wired up and everything where i want it i pulled it out to prep the engine bay and the rest of the car for paint and bodywork and decided insteaded of doing a basic rebuild on it i mite aswell do a 383 BUT on a budget since theres lots left to do on the car (custom paint, interior suspension, wheels) What you guys think??
Old Oct 29, 2009 | 10:18 PM
antsZRS's Avatar
Car: 1990 Camaro ZRS
Engine: 350 SBC
Re: BUILDING A 383 LT1
i would suggest the balanced rotating assembly from eagle for scat. since your wanna build a stroker motor. it comes with crank rods bearsings and pistons. cam wise i would say maybe a .525 lift maybe? i have a lunati vood series. and it seems to be doing quit well. and cams hard too. as for the springs i would go with the same brand as of whatever brand came you put in. hence my cam lifters springs caps and locks are all lunati. the valves i have are manley.
Old Oct 30, 2009 | 05:48 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Define BUDGET?
Speed costs ; how fast can you afford to go?
Old Oct 31, 2009 | 06:54 PM
88LT1Drop's Avatar
Engine: 96 LT1
Axle/Gears: 3:73's
Originally Posted by vetteoz
Define BUDGET?
i dont wanna spend more then $3000 on parts including machining $3500max if i have to. I was looking at the eagle stroker kit it looks pretty good for under $1000 comes with pistons and everything. But what should i do for lifter, springs, rockers....? hydraulics or roller? what difference do the two make?
Old Oct 31, 2009 | 11:03 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The two types are flat tappet or roller cam .Both both use hydraulic lifters.
Your engine has a hydraulic roller cam, keep the same type.
Kits with cast crank / Hyper pistons can be had from $700 up.
http://cgi.ebay.com/ebaymotors/SB-CH...Q5fAccessories
For $1000 you should be getting forged pistons
Any 383 SBC kit to suit a 1 peice rear seal engine ('87+) will work; it doesn't have to be advertised for a "LT1"
Old Oct 31, 2009 | 11:07 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Need a plan.
Are you keeping stock heads , getting them ported or buying aftermarket?
Lloyd Elliot has a very good name with the LT1 crowd and does some nice matched head / cam packages
http://www.elliottsportworks.com/lt1.html
http://www.horsepowerjunkies.com/for...ad.php?p=78224
http://www.camaroz28.com/forums/showthread.php?t=675568
http://www.camaroz28.com/forums/showthread.php?t=675034
Old Nov 1, 2009 | 08:41 PM
88LT1Drop's Avatar
Engine: 96 LT1
Axle/Gears: 3:73's
yea i'v heard of lloyd elliots stuff and ppl are making pretty good power with even a 355. Im keeping the stock heads and getting them ported and polished
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
L0tuS
Sep 4, 2015 11:16 PM
