Need help! Timing question
Old Nov 5, 2009 | 05:09 PM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
Soooo a couple months ago i pulled my top end in order to swap to carb. In my haste and ignorance i only managed to mark where the distributor was facing and not the order of the wires. I THINK I've come up with a way to solve the problem by running the plug wire to the cylinder the rotor is pointing at and figuring the rest of the timing from there. Will this work correctly? any advice would be welcome.
Old Nov 6, 2009 | 11:28 AM
toomany's Avatar
Re: Need help! Timing question
http://www.joby.se/corvette/misc/firing_order.gif
You will still need to make sure the rotor is pointing the correct direction. Did you bring the number 1 cylinder up to TDC on the compression stroke before tearing it appart?
Old Nov 6, 2009 | 11:49 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Old Nov 7, 2009 | 08:41 AM
Grumbles's Avatar
No, it's not at TDC. If I can get it to crank over i'll crank it to TDC and go from there.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
