Little Help please?
Old Nov 10, 2009 | 11:24 AM
Deadd's Avatar
Car: 91 Formula Firebird
Axle/Gears: 373
Little Help please?
Ok, So hear is the deal. I have a 91 Formula Firebird, and the A/c - Heater will not blow at all, this has been a problem for awile and i cant figure out what is wrong with it.I have replaced all the Relays and Resistors, the Switchpanel, and tested the blower motor and it works fine. With winter just around the corner id like to get this fixed.A Little Help Please?TY in advance for everything, Deadd
Old Nov 10, 2009 | 12:34 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Little Help please?
Been there an wound up in the same place, my fix was to wire a toggle switch on the dash to send a full 12v to the blower motor directly.
Which is about twice as high, as high. Blows like crazy.
Old Nov 10, 2009 | 01:07 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Mine had a bad ground on the fan itself..
Old Nov 11, 2009 | 10:24 AM
Deadd's Avatar
Axle/Gears: 373
Thanks for the imput, im trying to look for something that still will make this work properly im looking to make this into a show car, If there is any other suggestions please let me know thank you
Old Nov 11, 2009 | 10:52 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Just fake it, do like I did but hidden, using the stock stuff but wired direct.
Old Nov 11, 2009 | 12:51 PM
Deadd's Avatar
Axle/Gears: 373
oh i got it just use the 12v source on a toggle and use the factory controls, it will all still work just have a little more juice cause of it getting pure 12v?
Old Nov 11, 2009 | 12:54 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Yea something like that, it will run faster getting a full 12. But you should be able to hide everything just fine and make it look as if it works like stock.
Old Nov 11, 2009 | 01:13 PM
Deadd's Avatar
Axle/Gears: 373
delete
Old Nov 11, 2009 | 01:14 PM
Deadd's Avatar
Axle/Gears: 373
ok thanks a bunch, ill give that a shot this weekend and ill let you know how it goes
