Do you have to prime fuel system? EFI
Old Nov 16, 2009 | 09:23 PM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
I replaced my fuel tank, fuel pump, filter, feed/return lines, and rebuilt my fuel rail. I energized the fuel pump and heard it humming and pushing air through the system but no fuel. Do I need to prime the pump somehow? I turned the pump off and on for at least 3 minutes.
Thanks for your help!
Old Nov 16, 2009 | 09:43 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Do you have to prime fuel system? EFI
So long as the pump is drawing fuel and not air it should self prime.It could however be leaking up stream of the pump but still inside the tank
Old Nov 16, 2009 | 10:57 PM
wildjyoung's Avatar
I am not sure how it could leak. I did not use the pulsator but instead used high pressure fuel line with hose clamps. Something just seems odd. I would think the prime would prime by itself as well but fuel does not even sound like it is getting close to the rail. I jsut thought since the entire system does not have fuel it would need to be primed. It just sucks to be this close but not able to get the car started.
Old Nov 17, 2009 | 12:00 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
pump running backwards?-check valve should keep it
from pumping backwards,but you will still hear it run
-take the feed hose off under hood,cover end with a rag
to prevent splash,run pump for a second to see if any
fuel is pumped,if not time to start checking...
Old Nov 17, 2009 | 07:38 AM
wildjyoung's Avatar
Wow, I hope that is not the case. I have no idea how it could be backwards as I used the existing harness. If it is in fact running backwards, can I just reverse the wires leading to the connector behind the back seat?
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 25, 2015 08:05 AM
