what do you think this is worth
Old Nov 17, 2009 | 01:17 PM
Whoboy580's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Transmission: Powerglide
Axle/Gears: 4.10
Hey i was wondering what you guy think this motor is worth and if there is anything else you want to add.
406 Small Block Chevy- 4 bolt main casting# 3951511
Procomp Aluminum Heads- 64cc 2.02"intake 1.60"exhaust and 210cc runner
1.6 roller rocker w/stud girdles
SCAT 9000 cast crank w/ SRP flat top forged pistons, internally balanced
Edlebrock Dual plane intake
Weiland Single plane intake- 7546
Big ***** Thumpr comp cam- Hydraulic Flat Tappet , grind # 295TH7
SRE mini torque starter
Motor will also come with stock heads
Was built to run on pump gas with aprox 10:1 comp ratio
Motor has aprox 1000miles on it, never raced
Old Nov 17, 2009 | 01:23 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: what do you think this is worth
I would expect the value is about 5k dollars..more with parts separate Im a regular dude, no expert. I like those 1.6 roller rocker w/stud girdles very fascinated. Hmm. it could well be worth 7 if it is blueprinted block
Old Nov 19, 2009 | 09:40 AM
MitchellDeMoor's Avatar
Car: 1991
Transmission: 700
Couldn't agree more!
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
6998poncho
Sep 25, 2015 02:56 PM
