need help with speedometer wiring
Old Nov 26, 2009 | 09:17 PM
z28frost91's Avatar
Car: 91 Z-28
Engine: fresh 355 carb'd
Transmission: 700-R4
I have a 91 z28 with a 350 TPI. I recently spun a rod bearing and pulled the motor/tranny to rebuild. Through the process i decided to go carburated and eliminate the ecm. I was planning on selling the tpi and harness so i pulled the entire harness. I kept the tcc plug, all the relays, and everything i would need to keep gauges working except one important plug........the speedometer. My question is can i get the original gm plug and wire it to the speedo wire in the dash?? if so, how do i go about this?? and if not, what are my options. The car has a vss and i left all the wires going through the driver side of the firewall. any help would be greatly appreciated
Old Nov 26, 2009 | 10:25 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: need help with speedometer wiring
Depends on year ;
one has VSS signal going to the computer then dash ; the other goes to dash then computer.
Can't recall which years are which
Might have to get aftermarket speedo
Old Nov 28, 2009 | 09:40 PM
z28frost91's Avatar
Car: 91 Z-28
thank you for the resonse and i was trying to avoid an aftermarket speedo because i would have to re-do the entire cluster when i had one that was completely functional. i guess i'll try to reconnect the wires and i'll update how it goes. thanks again for the response
AUZ28
Oct 12, 2015 08:40 AM
LittleFranks
Sep 17, 2015 12:22 PM
AUZ28
Aug 26, 2015 06:08 PM
AUZ28
Interior Parts Wanted
Aug 25, 2015 07:29 AM
marcusaw
Aug 10, 2015 08:13 AM
