Heard loud pop and car is down
Old Nov 27, 2009 | 06:31 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
I'm riding my monsta scooter and saving gas but not by choice. What's shorting?
Tuesday AM, started to turn key as normal, seemed to be that before key got to crank position lost all power to everything.
Wednesday replaced old battery, its almost winter anyway. Double checked new battery 700 cca, fully charged, so installed. Dome light came on, stated to slowly turn key, but... seemed to be that before key got to crank position lost all power to everything. Disconnected battery.
Friday, all fuses look good. All wiring looks good, not melted or disconnected. Reconnected battery, dome light came on, started to slowly turn key and this time got to the crank position, and as soon as the key got to crank position HEARD A POP FROM PASSANGER SIDE and immediately lost power to everything. Disconnected battery.
What's the most likely problems and solutions?
Old Nov 27, 2009 | 07:01 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Heard loud pop and car is down
Check battery cable connections on both the battery and starter.
Old Nov 27, 2009 | 09:53 PM
Guest
Guest
Posts: n/a
Loose cables or connecters....
Old Nov 27, 2009 | 11:45 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
unfortunately GM put a fuseable link in one of the main power wires all the way down by the starter ( ) sounds to me like that is probably the problem.
best of luck-
Eric
Old Dec 1, 2009 | 07:57 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Checked and found it was a lose wire to the starter. Glad it wasn't a fusable link because that search wasn't going very fast!
Steven 86IROC-Z
May 24, 2026 04:52 AM
MustangBeater20
Oct 29, 2022 09:20 PM
RazorN8
Jan 7, 2022 11:44 AM
MENINBLK
Aug 5, 2015 11:58 PM
