The bird has a miss
Old Dec 1, 2009 | 07:38 AM
morg man's Avatar
Car: 89 Formula 350
Engine: TPI 350
Axle/Gears: 3.27s for now
The bird has a miss
Hi everybody. I have an 89 formula 350 with about 120,000 on it. I've done a 5 speed swap, headers, full exhaust, no cats, ac and smog delete pullies, and a sinister performance chip. The car ran fine for a while but has developed a miss lately. At first it was just every now and then but now its pretty much constant. I've changed the plugs and the cap and button so far. I'm going to change the plug wires next. A friend of mine did the old gear head trick and held a dollar in front of my exhaust and every now and the it looked like it actually tried to suck the dollar up the tail pipe. He said that usually points to something in the valve train, like a bent valve or somthing. I was just wondering if any of you guys have any suggestions for somthing to try. Thanks guys.
Dave
Old Dec 1, 2009 | 10:47 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: The bird has a miss
Check resistance of your fuel injectors. (engine at operating temp first please.)
Old Dec 1, 2009 | 11:21 AM
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
Check all of the wires and pigtails that connect to your ignition coil and distributor as well. A had a couple of damaged wires that caused this problem.
87v6Bird
Jul 1, 2018 04:12 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
BrianI
Oct 3, 2015 12:57 PM
Damon
Sep 26, 2015 04:29 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
