L98 must use shaft rockers??
Old Dec 9, 2009 | 04:05 PM
Red89C4's Avatar
Car: 89 Vette - 2009 Vette
Engine: L-98
Axle/Gears: 3.07 .... for now
I was going to have a shop install ZO-6 lightweight valves in my GM Alum heads but found that Manley states you need shaft mount rockers when using the 5/16" stem valves and that is the stem size of the ZO-6 valves, is this true??
Old Dec 9, 2009 | 05:09 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: L98 must use shaft rockers??
That seems really odd.... considering that with center bolt valve covers.... putting shaft rockers in there just isn't going to work......
I would call their tech line, and ask directly.
Old Dec 10, 2009 | 01:19 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Why would you go to the trouble / cost of installing smaller stem valves in a set of 113 heads?
You can buy aftermarket lightweight valves with the correct stem size that don't require any other changes
Old Dec 10, 2009 | 06:29 AM
Red89C4's Avatar
Engine: L-98
It's just a matter of saving money...maybe ! I have multiple sets of LS1 valves left over from the engines I had for my 98, and now that it's gone, and can't return the new sets, I'd like to use them in the L98. If I am going to install the same size valves as the ZO6 had, and already have them, I'd like to know if it's fesible without spending as much as buying completly new sets.
Old Dec 10, 2009 | 06:43 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
8mm LSx type valves dont need shaft rockers... I ran them just fine on my L98 with standard small block chevy rockers. Non self aligning with guideplates
AFR heads for small block chevy use 8mm valves
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
6998poncho
Sep 25, 2015 02:56 PM
ericjon262
Sep 11, 2015 06:07 PM
