Question about ignition coil.
Old Dec 30, 2009 | 09:56 AM
Camaro Man 02's Avatar
Car: 1987 Camaro IROC-Z
Axle/Gears: Idk
Ok, my gm blaster ignition coil just took a crap. Should i buy that same one or get the streetfire one? I have this older accel coil, but its HUGE. Will the accel one work or not cuz of the size? another question is how do you change out the ignition coil? i cant get to the bracket bolts.
Old Dec 30, 2009 | 10:44 AM
Axle/Gears: Idk
Re: Question about ignition coil.
anyone?
Old Dec 30, 2009 | 09:18 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
You could do whatever. Generally speaking no theres no reason to even go beyond stock and heres why. The way a spark plug works is it needs enough voltage to create a spark. The key in that sentence is they need enough voltage to create a spark. Having a 100k volt coil will do nothing over a 40k coil as a spark plug may only need 30k volts to cause a spark anything over that will be sort of shorted out in essence. So really there's no reason to go beyond stock unless you were running a racing fuel or in really high RPMs. So your choice.
Old Dec 30, 2009 | 11:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The time it takes a coil to saturate sufficiently to produce that 30kV does matter. And that's where stock coils fall short. 4500 RPMs is about all they can typically handle.
What else do you have for ignition? MSD specifies different coils for different ignitions.
Old Dec 30, 2009 | 11:33 PM
Axle/Gears: Idk
well, i have an msd multispark box. but my question is how to replace the coil. it looks really tight in there by the screws.
Old Dec 31, 2009 | 01:18 AM
ShMaCk2004's Avatar
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
reach for them or take things off to get to them, theres always a way
db057
Aug 22, 2015 08:17 PM
theurge
Aug 21, 2015 12:46 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
