changing belt
Old Dec 30, 2009 | 11:29 PM
J-money's Avatar
Car: 92 RS camaro, 99 Z-24 cavalier
Engine: 5.0L TBI, 2.4L
changing belt
ok i have a quick question about changing the serpinetine belt on my 92 RS (5.0L). The box the belt came in has some not so discriptive instructions about adjusting tension on the belt, and on the tensioner pulley the marks are off a little. Can I just put the new belt on as is or do I need to adjust the tensioner pulley before I put the new belt on?
Old Dec 31, 2009 | 03:35 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: changing belt
tensioner is self adjusting. No need to mess with anything, just pop a ratchet in there, pull, drop the old belt, route the new belt and put the tensioner back in place, as far as i know the only way to "fix" then tensioner is to replace it
Good Luck
Old Dec 31, 2009 | 06:54 AM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Re: changing belt
That would be correct, I've never heard of a way to adjust a tensioner, you would replace it.
Old Dec 31, 2009 | 06:57 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Re: changing belt
Yeah, its that easy. Pop the ratchet on there and on and off it goes quickly. It should take you only a couple of minutes. No adjustment needed.
Old Jan 1, 2010 | 12:21 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: changing belt
the only "adjustable" tensioner ive ever seen is on mitsubishi style motors, annoying pieces of garbage and reverse threaded if i remember correctly, i watched my friend over tension multiple belts on his eclipse and just burn thru them like crazy
Old Jan 1, 2010 | 08:40 AM
J-money's Avatar
Re: changing belt
how do you know when to change the tensioner pulley? my car has around 200,000 miles on it. should I change that as well or just go ahead and put the belt on it?
Old Jan 1, 2010 | 08:47 AM
AC's Avatar
AC
Car: Used to drive a camaro
Re: changing belt
Just put the belt on. You would change the tensioner if the spring was shot (I've NEVER in 17years of owning 3rd gens seen one needing it).
Old Jan 1, 2010 | 05:28 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: changing belt
same here. If your belt is new and slipping then you have an issue but if its not broken dont fix it. And in case theres any confusion if you buy a cheap belt then youll have issues but thats only in the useful life of it, ive used everything from gatorback belts to cheap autozones and the only issue is how long it lasts and ive never known anyone to need to replace the tensioners on these cars
Old Jan 1, 2010 | 11:34 PM
J-money's Avatar
Re: changing belt
Okay, thanks for the help.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
mustangdmurder
Aug 21, 2015 07:17 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
scottmoyer
Aug 9, 2015 10:18 PM
