car smells like gas
Old Jan 3, 2010 | 05:01 PM
camaro_mann's Avatar
Car: 1986 Iroc-Z28
Transmission: 4L60
Axle/Gears: 373
car smells like gas
i never realized that my car smells strong like gas or maybe exhaust, ive' had the car for 2 years so im just happy to have it so maybe thats why i didnt realize it smelled so strong...someone told me carbon monoxide. my o2 sensors are working so what do you guys think?? its a 86 iroc 350 swap tpi 24 lbs accel injectors... the exhaust isnt leakin, hedman headers 3 in. flowmaster... let me know what you guys think.....
Old Jan 4, 2010 | 06:22 PM
TheAdmiral's Avatar
Car: '89 IROC
Axle/Gears: Stock, 2.73?
Re: car smells like gas
did you get your computer reflashed to accept the 24lbs. injectors? if not that may be the problem. stock lbs./hr. is 19lbs. make sure your computer was reflashed to accept them.
Old Jan 4, 2010 | 09:45 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
is it smell like fuel, like raw gasoline...or does it smell like exhaust. Usually you can hear and exhaust leak.
There is a gas tank vent located underneath your car infront of gastank that sometimes need replaced, that could cause a raw fuel smell.
An exhaust leak usually has black carbon streaks where it is leaking from....and a muffler shop should be able to check it for leaks for free if you can't get under the car.
Old Jan 5, 2010 | 06:54 PM
Car: 1986 Iroc-Z28
Transmission: 4L60
Axle/Gears: 373
thankz for the info....i have a custom chip so im pretty sure they did program everything for the bigger injectors....it is more like exhaust smell but it smells bad as it comes from the tail pipes....one time my spark plugs filed out and it is feeling a lil sluggish "boggin down a lil" so ima change them out again....
bryan623
Mar 22, 2021 06:43 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
