cam thrust plate torque specs
Old Jan 7, 2010 | 12:12 PM
mgilorma's Avatar
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
I found online for a ford it should be 8 - 10 ft/lbs, do you think it is the same for a 305 sbc? Can't seem to find the spec anywhere.
Old Jan 7, 2010 | 12:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: cam thrust plate torque specs
Sounds about right, I'd make it "snug" and not worry too much about the actual torque value.
Old Jan 7, 2010 | 12:26 PM
mgilorma's Avatar
Car: 90 RS
The only reason I'm interested is because I already broke a bolt off in the block the last time I tried to install the cam plate. Just wondering if anybody knew for a fact.
Old Jan 8, 2010 | 03:08 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
The 96 FSM says 106 in/lbs NOT ft/lbs - 12 N-m
Jake
Old Jan 8, 2010 | 03:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
106 in-lbs = 8.5 ft-lbs
Old Jan 8, 2010 | 03:13 PM
mgilorma's Avatar
Car: 90 RS
Sweet! Thanks for the info!
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
deracer
Apr 11, 2016 12:04 AM
LT1Formula
Nov 16, 2015 01:13 PM
gwade12
Aug 8, 2015 08:17 AM
