Oil cooling/performance?
Old Jan 7, 2010 | 05:27 PM
101btp's Avatar
Car: 86 Trans am
Engine: workin on a 383 for it!
alright, I wanted to put on a new oil pan and probably upgrade from a stock oil pump to a higher volume, But I wanted to know is their really any advantage to a remote oil filter relocation kit? and is it a big benifit to add one of those oil cooling small sized radiators? O or also adding a radiator filter/ inline cooling radiator?
Old Jan 7, 2010 | 05:33 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Oil cooling/performance?
Why? All it is going to do is pump more oil upstairs and risk running the pan dry, like under hard braking where the oil moves forward away from the pickup.
Makes it easier to change oil filter
Yes but only if you are seeing higher than normal oil temps from running the engine under load at high revs like track racers
Old Jan 7, 2010 | 07:55 PM
101btp's Avatar
Car: 86 Trans am
because im getting a bigger than stock oil pan, and the pump comes with a new pickup, but with the relocation kit won't you add a nother place on the kit 2 go wrong?
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
