Replacing a crank
Old Jan 15, 2010 | 01:54 AM
carfreak614's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: Open 2.73
Replacing a crank
Ok, im lookin into buying a 89 z28 from a guy here locally. The only thing wrong with the car is that the guy says it needs a crank, he says it runs but it sounds really bad.
How hard is it to replace a crank? I would assume some difficulty but i got some time b4 the track opens around here and this would give me a project to work on
Old Jan 15, 2010 | 06:42 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: Replacing a crank
It's not that simple that block will have to be completely reworked. You may be better off buying a rebuilt short block.
Old Jan 15, 2010 | 07:35 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
How would he know if the crank needs to be replaced just by sound?
If it's a good deal, buy it. At least you'll get a car out of it and you can build the engine the way that you want.
Old Jan 15, 2010 | 01:47 PM
Car: 92 Camaro RS
Engine: 305 TBI
Yeah I think Im jus gonna buy it and then jus get another short block, cuz its really a nice lookin car. The only thing reallhy visually it needs is some interior work but thats it.
Heres some pics of the car
Attached Thumbnails Replacing a crank-2010_01120116.jpg   Replacing a crank-2010_01120117.jpg   Replacing a crank-2010_01120123.jpg
Old Jan 17, 2010 | 08:08 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I agree with the comments above. If this guy is not asking too much for the car, then buy it, expecting that you will have to put a new short block into it. I dont see how a person can tell that thee crank is bad by the sound of it. Very likely, there is something else wrong with the engine. Also, as staed above, you just dont replace a crank. There is alot more work to be done.
Old Jan 17, 2010 | 04:38 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
"needs a new crank" = "needs a new engine"
(or at least a rebuild)
TheExaminer
Aug 26, 2015 04:59 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
mizz0313
Aug 12, 2015 06:45 AM
