Removing Air Pump change timing?
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
I removed the air pump because it started ticking and rerouted the belt.
Could this throw of the timing? I havent had the emission stuff hooked up in over a year and have no cat but left the air pump or smog pump on so i didnt have to run a new belt but it was ticking and i removed it. Car ran fine for 30 minutes and now idels low. Sounds as if its gargling
