Can I run my motor on pump gas? Info inside
Old Jan 26, 2010 | 07:39 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
I dont have head gaskets yet but I figured .040 for my gaskets.. Will I be ok to run 93oct pump gas.....this is what I pulled from wallace racing
Static compression ratio of 10.53:1.
Effective stroke is 2.90 inches.
Your dynamic compression ratio is 8.25:1 .
Your dynamic cranking pressure is 165.44 PSI.
Your dynamic boost compression ratio, reflecting static c.r., cam timing, altitude, and boost of 3 PSI is 9.93 :1.
V/P (Volume to Pressure Index) is 148
Old Jan 26, 2010 | 08:08 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
Re: Can I run my motor on pump gas? Info inside
no problem with 93 octane.
Old Jan 26, 2010 | 08:12 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Ok, I thought I read a dcr of 9 was the the max and since Im almost at 10 I wanted to make sure
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
