Fuel Pump Question?
Old Feb 4, 2010 | 10:13 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Fuel Pump Question?
I did some searching around a couple different sections but I was surprised that I couldnt really find an answer to my question. I was curious as to what the limits of a stock fuel pump are? The car was originally an LB9 now I'm dropping in a 355 with RHS pro-torkers, xe-268 cam, HSR, 24lb injectors, and I'm thinking of setting the fuel pressure to about 44-45psi, and I'm wondering if I will be maxing out the stocker? Thanks.
Old Feb 5, 2010 | 09:46 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Re: Fuel Pump Question?
Mine is a LB9 tpi stock elec pump is 45
Old Feb 5, 2010 | 11:57 PM
Car: '89 IROC-Z
Engine: LSx
45 what???
Old Feb 6, 2010 | 12:10 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Originally Posted by IrocZ30589
45 what???
Hello IrocZ30589!!
45 PSI
**Right out of the 1987 Camaro service manual, the stock pump for a 5.0/5.7 liter TPI, puts out 40.5 - 47 psi fuel system pressure at the test port, key on engine off!!
Engine running, 34 - 47 psi, regulated by the fuel pressure regulator.
The pump will put out more than 60 psi if you "dead head" the pump by restricting the fuel return line, "not recommended"
Old Feb 6, 2010 | 08:08 PM
Car: '89 IROC-Z
Engine: LSx
Is it enough to feed my combo? It fed my 355 TPI fine with the same heads, but I'm switching to an HSR a bigger cam, complete exhaust, more agressive tune, and just about every bolt-on and some off there is.
Old Feb 8, 2010 | 12:50 AM
Hello IrocZ30589!!
I don't really know about that, but look at it this way, the PSI might be good enough with a stock pump, however the flow rate of gallons per hour might not be enough to handle it.
You might run into fuel starvation problems!!!
More thought process is required, to give you a better answer, or at least the one your looking for!!
Old Feb 8, 2010 | 01:23 AM
Guest
Guest
Posts: n/a
Its entirely dependent upon how much power you're making. However for most of us the stock pump will flow plenty, should be enough to support above 400HP depending on your BSFC.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
