fuel pump internal
Old Feb 8, 2010 | 10:40 AM
C_Sander's Avatar
Car: 91 Camaro RS
Engine: Carbureted 305
fuel pump internal
simple question:
my fuel pump and wiring harness in my car has three wires: purple, black, and grey
my new fuel pump replacement only has two wires: grey(+) and black (gnd)
what do i do with the purple wire? It is not mentioned in the Haynes manual either, it only has +/gnd..??
Old Feb 10, 2010 | 12:32 AM
C_Sander's Avatar
Car: 91 Camaro RS
Re: fuel pump internal
edited question..plz answer asap
Old Feb 10, 2010 | 12:34 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Fuel level sender.
Old Feb 10, 2010 | 09:44 AM
C_Sander's Avatar
Car: 91 Camaro RS
ahhh should have thought of that..thanks for the quick reply
Old Feb 11, 2010 | 04:05 PM
jer4251's Avatar
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
I'm having issues with the level sensor. Ive got gas in the car, but its showing full to the max, way past full. It use to be up and down constantly, but now its just past full forever. I had a look in the tank and the float seems to be working fine. where can i track down the purple wire to? I'm thinking i have a short in the wire somewhere. I havent climed under the car to try and chase it down, anyone know where it is a good place to tap into the tire to test it?
Old Feb 11, 2010 | 05:17 PM
C_Sander's Avatar
Car: 91 Camaro RS
the purple wire goes into the car, and runs under the carpet on the inside, not the outside. From there, im not sure. I know i saw a purple wire in the fp relay, but not sure if thats the same one.
Old Feb 11, 2010 | 05:54 PM
jer4251's Avatar
Car: They all sit.
I see where the wires go into a plug right infront of the tank, goes through the backseat wall down the hunp and over to the drivers side harness, under the door sill and to the underside of the dash. didnt see anything wrong with any of that.
What ground wires/locations, could cause the problem? I'm thinking its a ground wire now. Have always had little wiring issues with the car
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
theurge
Aug 21, 2015 12:46 PM
92camaroJoe
Aug 13, 2015 06:07 AM
