Flexplate inspection..Help!!
Old Feb 23, 2010 | 07:34 AM
Gadp74's Avatar
Car: Firebird Formula 1989
Engine: 305, TBI
Is the an easy way to inspect a flexplate for loosen bolts or cracks without moving the transmission? I have a ticking/knocking noise coming from there.
Thank you.
Old Feb 24, 2010 | 08:39 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Re: Flexplate inspection..Help!!
There is an inspection cover over the FP. Take that off. Get a good flashlight and check to see if there are cracks on the FP. While under there you can move the FP and see if there is play. Also check to make sure your torque converter is tight aswell.
BTW, i have the same exact problem, but havent confirmed thats my prob yet since the car is in storage.
84LsxZ28
May 17, 2020 02:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Stangski09
Nov 14, 2015 01:27 PM
roysatikas
Sep 22, 2015 08:15 PM
roysatikas
Sep 7, 2015 08:08 PM
