Oil rings - Can they be installed with these still on them?
Old Feb 24, 2010 | 01:29 PM
87_LG4's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
Transmission: TH-700R4
So I'm ready to install my pistons, and the only thing stopping me is weather or not I need to remove these colored pieces from the gaps of my oil rings:
They are the oil rings from this set. What do you think?
Thank you.
Old Feb 24, 2010 | 01:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The ends of the expander are painted so you can easily see they butted end-to-end and aren't overlapped when you go to install the piston.
Old Feb 24, 2010 | 01:54 PM
87_LG4's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
Re: Oil rings - Can they be installed with these still on them?
Rightly so, but if you look closer you'll see that the painted parts nearest to each other are made of plastic (most likely) and are stuck onto the metal. Are they supposed to be there upon installation?
Old Feb 24, 2010 | 04:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yes
Old Feb 26, 2010 | 03:19 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
QUOTE=Apeiron;4448842]Yes[/QUOTE]
Jake
hectre13
Dec 11, 2023 08:14 AM
toronto formula
Nov 10, 2015 06:17 AM
hectre13
Aug 26, 2015 08:17 AM
Navy8125
Aug 21, 2015 09:32 AM
Cameeeero
Aug 20, 2015 03:06 AM
