Name that sensor!
Old Feb 25, 2010 | 09:52 PM
SargeantSarkasm's Avatar
Car: 1989 Pontiac Trans Am
Engine: 350 TPI L98
Axle/Gears: The ones with the teeth.
Name that sensor!
Standing at passenger side, looking towards rear of block, just below header and in between plugs. I found this single wire broken, looks as if it goes into a nearby plug which goes into the block.
Any ideas?
Old Feb 25, 2010 | 10:06 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Name that sensor!
Fan Switch - it turns on the elctric fan when it reaches preset temp.
Old Feb 27, 2010 | 12:58 PM
Engine: 350 TPI L98
Thank you sir. I've been having fan issues for a long time. Ended up doing Willie's dual fan mod to get around it.
I'll have to look at some wiring diagrams to figure out whether it grounds the primary or the secondary. Can't remember how that all worked.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
