Intake Vacuum Hose
Old Feb 28, 2010 | 12:19 PM
Damnaged's Avatar
Car: 89 Chevy Camaro RS
Engine: v6
Transmission: A4
Intake Vacuum Hose
Initially, where is it? I just bought an 89 Camaro RS 2.8l v6. I don't know much about car as it is. I'm trying to fix that. I have every 89 Camaro repair manual I could find on the way.
From what I've been reading, there is a good chance that I have a severe carbon build up problem. I bought c-foam to run through the carb to see if that will help with the problem.
I can't find the main intake vacuum hose that I am suppose to pour the c-foam into.
"Performing a Sea Foam Engine Treatment on a Fuel Injected Engine Begin by parking the vehicle in a well ventilated area. Locate a vacuum line that you are certain DISTRIBUTES EVENLY TO ALL CYLINDERS. On many vehicles the easiest option is taking the vacuum line from your brake booster PCV."
Old Feb 28, 2010 | 07:55 PM
copyfixr's Avatar
Car: 88 Camaro
Engine: 2.8v6
Transmission: 700 R4
Re: Intake Vacuum Hose
It is fuel injected, on the rear of the intake, look for a large black vacuum line that runs to the break booster. It is a T fitting with a plug on the opposite side. Remove the cap, attach a long piece of vacuum line and put it in the can. Just bought an 88 with a v6 for my son's first car and did this to his. Smokes like heck but seems to help. I run Sea Foam in everything I own.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
snakeshooter
Sep 7, 2015 11:13 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
