fuel injectors what to buy?? so many to choose from...
Old Mar 1, 2010 | 04:21 AM
fbodygirl's Avatar
Car: '87 Pontiac Firebird
Engine: 2.8 V6
Hello all, I am looking to replace my injectors. But what to get, do I buy remanufactured? or new? or have them cleaned? I don't have a lot of money to spend so it is an issue, something mid priced would be great. Anyway just want to know what's good, and what would be the best way to go. Any help would be great. Thanks!
'87 Firebird, V6 2.8 stock
Old Mar 1, 2010 | 06:05 PM
randyz91's Avatar
Car: 1991 z28
Engine: 5.7 tpi
Transmission: th700r4
Re: fuel injectors what to buy?? so many to choose from...
South Bay fuel injectors is a board sponsor. I do not have a link right now.{sorry), but do a search. I have done business with them and they were very helpfull. No complaints. Randy
Old Mar 1, 2010 | 06:07 PM
Jordo91rs's Avatar
Car: 91 camaro rs
Transmission: t-5
Axle/Gears: 3.23 gears
I have heard the ones made by accel work pretty good.
Old Mar 1, 2010 | 06:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Why are you replacing the injectors?
Old Mar 1, 2010 | 08:42 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
http://www.youtube.com/watch?v=Emnax2J4FX4
Old Mar 2, 2010 | 02:49 PM
fbodygirl's Avatar
Engine: 2.8 V6
Hello, thanks I'll try looking south bay up.
I'm replacing the injectors because I'm pretty sure more then one or two are leaking, the car has over 168,000 miles on it, and they have never been replaced, it also runs really rich and idles terrible, and when I start it, it blows blue smoke at start up. I also had to turn up the idle screw to get it to idle and not die, so i'm pretty sure it needs more than a tune up, which has been done with no change. So I think it's time for new injectors. But there are so many choices, not sure if I should have them cleaned or buy remans or new ones.
Old Mar 2, 2010 | 03:26 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
It sounds like it need more than just new injectors.
Blue smoke at start-up is usually worn valve guides and valve seals.
You could test for leaky injectors by using a fuel pressure gauge on the fuel rail.
If after running for a while, you then shut the engine off for about 15 minutes, then try to start and it's very hard starting, that's a symptom of leaking injectors.
Old Mar 2, 2010 | 03:56 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
www.racetronix.com
Old Mar 3, 2010 | 08:17 AM
southbay08's Avatar
if you want to do a quick check for leaky injectors after running the car pull the plugs...if you have a wet cylinder you have a leaky injector. If any of you ever have a question regarding injectors please do not hesitate to contact us...we will do our best to help!
www.southbayfuelinjectors.com
info@southbayfuelinjectors.com
516-492-6504
bryan623
Mar 22, 2021 06:43 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
