Help! Where Is My Fuel Pump Relay Located?
Old Mar 1, 2010 | 05:52 PM
GtoRockz's Avatar
Car: 1987 Firebird
Transmission: R4
Axle/Gears: Stock
My 1987 Firebird 305 carb is supposed to have a second FP in the gas tank.
It is going in the shop first thing in the morning to drop the replace the pump.
I want to replace the relay first in case it is bad and not the pump but can not locate it.
Also, there is no fuse for "Fuel Pump" under the dash?
Old Mar 1, 2010 | 07:31 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Re: Help! Where Is My Fuel Pump Relay Located?
On the 90 camaro the relay is on the drivers side fire wall behind the brake master cylinder
Old Mar 1, 2010 | 08:03 PM
GtoRockz's Avatar
Car: 1987 Firebird
Transmission: R4
Axle/Gears: Stock
Thanks, the only relay i could find was by the battery, just went and got a new one but made no difference. Probably was the fan relay anyway. No FP fuse, no FP relay.. but they tell me there is a pump in the tank for the 1987 model..??
Guess i'll find out tomorrow when they drop the tank.
Old Mar 1, 2010 | 08:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Did you check both fuse panels?
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
