HELP PLEASE
Old Mar 4, 2010 | 09:31 PM
camarokid4liv's Avatar
HELP PLEASE
Hi, I have a 91 camaro RS and the motor turns over very slow and wont start. New battery. I swapped from the tpi to a 350 carb. It does have higher compression about 10:1. Getting 12V every where so i need some help please.
Old Mar 4, 2010 | 09:34 PM
CrimsonDragon's Avatar
Car: 89 IROC - 85 Z28
Engine: 350 / 305
Transmission: 700R4 / T5
Axle/Gears: Stock
Re: HELP PLEASE
Are all your grounds back in place? Check your ground cable at your battery and all the ones around your engine.
Old Mar 4, 2010 | 10:02 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Re: HELP PLEASE
sounds like low battery voltage or a weak starter.Check your battery voltage with a meter,if that's good,either your starter is weak or your timing is advanced way too far.
