What fuel do you use?
Old Mar 6, 2010 | 11:21 AM
86' Camaro's Avatar
Car: 1986 Camaro Z-28
Engine: 305 TBI
I was just wondering about what kind of fuel you guys use in your 3rd Gens? My dad is telling me that i should use regular (87 octane) in my camaro. It runs fine on that or silver (89 octane). What do you use in your car or what additives do you use such as octane booster or marvel mystery oil?
Old Mar 6, 2010 | 11:23 AM
84z .....'s Avatar
Car: Blue 84 z28/Cyber 2010ss/rs
Engine: Dart headed, 12:1 355- 510/530 cam
Transmission: TKO 600 Lakewood Bell
Axle/Gears: Richmond 410 Spooled
Re: What fuel do you use?
always Sunoco 94
Old Mar 6, 2010 | 12:07 PM
tucker07's Avatar
Car: 1984 Trans am
Engine: 305 H.O.
Axle/Gears: Stock gears
I only use 93 octane dont cheap out. it burns a lot cleaner less sulfer build up to.
Old Mar 6, 2010 | 12:50 PM
grassyflats's Avatar
Originally Posted by 84z .....
always Sunoco 94
Yes Sir!
I wish there was a Sunoco around here ...94
So I figure you get alot better mileage using high-test
and in effect it does not cost more money in the long run
-there are alot of different grades
of gasoline across the country-
I have gotten an extra 150 miles a tank full just by
filling up in the next state
-I always use 93 and a shot of gin
Old Mar 6, 2010 | 01:03 PM
86' Camaro's Avatar
Engine: 305 TBI
I think once i get my job at the local golf course, that i will switch to using 89 octane or 93 octane. Right now, im a little light on cash.
Old Mar 6, 2010 | 01:11 PM
sk8r fer life's Avatar
Car: 1990 camaro rs
Engine: 305 tbi
BP gas high grade (93 octane) owner before me, myself being the second, ran nothin but shell/BP 93 its a little more but definatley worth it
Old Mar 6, 2010 | 05:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The cheapest 85 octane I can find, with a shot of AMSOIL PI.
Old Mar 7, 2010 | 12:40 AM
camaro3554gear's Avatar
Car: 1991 Z28 (sold), 1987 Buick GN
Engine: L98 TPI, bored 0.040 over
Transmission: TH350, 2400 stall, shift kit
Axle/Gears: 10 bolt w/eaton locker, 3.42 gears
I always run the highest available octane which around here is 93, it just doesn't run the same on anything else.
Old Mar 7, 2010 | 01:17 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Regular 87 octane. If it's ruining my injectors I just sue Shell, BTW I work for Shell - Assisant Researcher.
Old Mar 7, 2010 | 01:45 AM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
I run 93 octane, but only because i have to. If you dont have really high compression or forced induction, you should run 87. No matter what anyone tells you, running higher octane dosen't run "cleaner" or give you more performance. If anything your mpg will go down and you will lose performance. Higher the octane number = takes longer to burn. Thats why if you have have forced induction or high compression you must use higher octane gasoline to keep detonation away. If you used 87 octane in my engine, it would ping because the fuel would ignite to soon as the piston was still coming up.
Old Mar 7, 2010 | 03:05 AM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
look in any hi-po mag and you'll see them say the same thing. most power comes from the lowest octane possible. use quality gas and maybe something with ethanol and you won't have any trouble gumming the injectors etc. I know some people hate ethanol but it burns cleaner and acts as a detergent even helping clean dirty injectors and fuel systems.
Old Mar 7, 2010 | 03:11 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
My CR is 10.5:1, no detonation, or ping. Not because I can't hear it but, because I would see the ECM pull timing when I data log.
Old Mar 7, 2010 | 05:37 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Use the lowest grade possible without pre-ignition.
Old Mar 7, 2010 | 08:31 AM
HankL69's Avatar
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
I always used mid-grade untill gas hit $4/gal. I switched to regular and noticed no difference, either performance or mileage. Why pay more, the gas companies get enough of our money the way it is.
Old Mar 7, 2010 | 11:14 AM
86' Camaro's Avatar
Engine: 305 TBI
Yeah, i noticed that some of my friends that have VW's and my one friend that has a Trans Am both all use 89 octane gas (in the middle of the octane's) on their cars'. My dad has a 64' Cadillac Coupe De' Ville, and he has to use 93 octane plus an octane booster everytime he fills it up.
Old Mar 7, 2010 | 03:35 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
When I worked in the chevy dealer, we saw vettes and camaro's at least once a week with running problems due to the high octane gas they were using eating away the insulation on the coil windings in the injectors. Bear in mind, that has been some time ago, and things may have changed, either in the formulation of higher octane fuels, or, in the design of the injectors. We always recommended 87 octane fuel for stock motors, or slightly warmed over ones.
Old Mar 7, 2010 | 03:48 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
E-85, 106 octane--works fine with 12.5:1 CR and 36 total advance in my (brand X) stroker, 2900 lb. 5 speed car. Setting my '82 Camaro up the same, maybe even a half point higher on compression....
Old Mar 7, 2010 | 04:59 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I was told that engines with a knock sensor will keep the timing advanced further if high octane fuel is used. I understand this theory, but I am skeptical.
Old Mar 7, 2010 | 10:18 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
94 Octane!!!
Check your owners manual, TPI VIN "F" or "5.7 liter V8" is "designed to operate on Premium"!! You can use the other "junk", but "at slightly reduced acceleration performance". I like performance, that's why I have an IROC, for the performance!!
Old Mar 8, 2010 | 04:35 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
The knock sensor only retards timing if it detects knock. If there is no knock on 87 octane, then the knock sensor is not retarding timing, hence no performance loss.
Run the lowest octane possible that creates no pre-ignition. This can only truly be tested with a scan tool or datalogger.
Old Mar 8, 2010 | 10:08 AM
Why do some drivers swear by using high octane fuel i.e. giving them better performance?
Old Mar 8, 2010 | 11:16 AM
Engine: 383 Stroker
Transmission: t-56
Oil companies love people like you!
Old Mar 8, 2010 | 11:29 AM
like the other guys are saying
the cheaper gas is better thats why they charge less money for it
Old Mar 8, 2010 | 11:56 AM
SeanW's Avatar
Unless you have the compression to justify it, higher octane gas will actually net you less power.
Old Mar 8, 2010 | 12:50 PM
If the oil co's like guys like me, they love guys with strokers!
Old Mar 8, 2010 | 12:53 PM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
I use to be runnin 91 oct, but I notice that my car was running worser and worser. Then I went with 87 and it is running well without a problem
Old Mar 8, 2010 | 01:04 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Because some engines knock on heavy load with low octane. The 4.0L I-6 in my jeep wrangler used to do that on 87 despite every sticker and label saying it only needed 87 and that putting in higher octane was useless.
Old Mar 8, 2010 | 04:44 PM
HankL69's Avatar
Engine: 5.0 / 350
The owners manual for my '85 says to use 87 octane.
Old Mar 8, 2010 | 05:07 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
It's either psychological or their engines were actually seeing spark retard.
Run premium at the track. Make a few runs. Average 'em out.
Put in high test at the track. Make a few runs. Average 'em out.
Run a scanner/datalogger during these runs. See what happens.
If you weren't experiencing retard during the premium runs, your high test runs will be no faster.
Old Mar 8, 2010 | 11:47 PM
Hello HankL69!!
Does it specify the engine code, or is it non specific???? My owners manual for my two '87's are specific, and gives the engine VIN code, telling me to use Premium Unleaded in 5.0 liter engine VIN Code "F" and 5.7 liter V8 engines!!
It tells me to use Regular Unleaded in 5.0 liter engines except engine code "F" and 5.7 liter V8 engines!!
Yours "should" be the same!!!
P.S. "Should" be the same, less the 5.7 liter reference, due to the fact the 5.7 liter wasn't available until 1987!!!
Old Mar 9, 2010 | 12:02 AM
Engine: 383 Stroker
Transmission: t-56
I really dont care what octane anyone uses, i was just trying to help you out. But some people are just hard headed. Enjoy whatever the hell you like.
Old Mar 9, 2010 | 12:30 AM
Sounds like "High Test" to me!!!
Old Mar 9, 2010 | 07:43 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
87 octane, with as little ethanol as possible.
At present (2010), the higher octane rating generally comes more from the higher concentration of ethanol than the actual "Octane" concentration being higher.
If you have a completely stock engine and you're getting knock unless you run higher octane fuel, then that's an indicator that something else is wrong.
You can generally make any engine knock if you have a manual transmission and you lug the engine.
Old Mar 9, 2010 | 08:29 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I run 93 or 94 because I have to. I agree that if the motor is stock, the 87 should be fine. I know in my onld 96 Firebird 3.8, it would run hotter and slower on 93. I only made that mistake once.
Old Mar 9, 2010 | 08:41 AM
B'tx's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Transmission: Manual
OK, just to make sure that I get what most are saying, I have a 92 Camaro TBI 5-spd stock engine. I should use the 87 oct? I use Shell gas BTW.
Old Mar 9, 2010 | 08:50 AM
HankL69's Avatar
Engine: 5.0 / 350
Originally Posted by 87IROC-DAN61
Hello HankL69!!
The '85 owners manual does not specify any engine codes in its fuel requirement section. At least mine does not.
Old Mar 9, 2010 | 08:56 AM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Always do 89 octane. Even shell's 87 octane is good. Shell's fuel period is great, according to the commercials and local tests my dad's dealership has done...
Old Mar 9, 2010 | 09:56 AM
By the way, my 86 IROC with a stock lg4 seems to ping slightly on exceleration with regular gas, so I use mid grade, and the ping stops. Probably a faulty sensor, but I just use mid grade, and run it. I suspect I have a HO cam in it. Maybe it is a bit warmed over. It does go like hell.
Old Mar 9, 2010 | 10:11 AM
five7kid's Avatar
More likely an inoperative EGR valve or plugged EGR passages.
Old Mar 9, 2010 | 01:37 PM
How do I unplug the EGR?
Old Mar 9, 2010 | 01:53 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Octane rating is purely anti-detonation characteristics, based on a comparison to pure octane. Contrary to popular opinion, higher octane ratings do not equal better performance, more power, or better economy, but are simply a requirement of higher-compression engines. You're just wasting money running a higher octane fuel than you need.
Old Mar 10, 2010 | 01:33 AM
  #42
Hello 305sbc!!!
I can't make my 305 TPI manual transmissioned electronically spark controlled engine knock, as the spark is retarded before I can detect it!!
I've even had comments about why it doesn't get the spark knock!!!
Old Mar 10, 2010 | 01:38 AM
  #43
Hello HankL69!!
You would think that they would put something in the owners manual about the premium fuel requirement, as the '85 TPI motor had a 9.5:1 CR, which you would think, necessitated the premium fuel!!
It's in both copies of my 1987 owners manual as I have stated before!!!
Old Mar 10, 2010 | 07:09 AM
  #44
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Im another for running 87 unless you need more.
In my 88 1500 (4.3 manual) I run 87 when Im doing daily driving. If Im going to be doing any hauling or towing, I run premium just because it will spark knock under a heavy pull.
I run highest pump octane possible in my s10 and chevelle and 400ex, thats because of the compression.
My camaro has stock compression so I run 87 with no problems. I have run 93 before and didnt notice any difference. So why pay more?
Old Mar 10, 2010 | 10:45 AM
  #45
My genuine question about knock sensors, is that they retard timing so you don't get ping. Well it stands to reason that if higher octane is used the engine will run w/timing more advanced.??
Old Mar 10, 2010 | 01:59 PM
  #46
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Assuming the sensor and system is working correctly as designed and you were getting spark knock and the resulting spark retard already, then switching to higher octane fuel "can" allow you to run with less retard.
The system does not add extra spark advance based on you putting in a higher octane fuel. A good running system will not be experiencing any spark retard unless it's running the self diagnostic knock test, or you overload the engine by lugging it.
To the guy that can't get spark knock, just get the engine to 220*F or higher, then try to climb a steep hill from a low speed in your top gear. Put the gas to the floor and you will get knock, and possibly damage your engine, so I don't recommend it. The system can only pull so much spark in a certain amount of time, and a limited amount of total SA.
If you can't hear the knock and want to keep an eye on it, there are aftermarket monitors like this one: http://www.jandssafeguard.com/
Old Mar 10, 2010 | 04:34 PM
  #47
"with less retard" is the key phrase that leaves me scratching my head. I have read that there was a bump up in hp with the introduction of the knock sensor. I am not trying to contradict or argue your point, I just want to understand.. Are you saying that with higher octane the engine will run with less retard, or more advance than with less octane?
Old Mar 10, 2010 | 07:07 PM
  #48
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
POSSIBLY less retard, IF you were getting retard before, which you shouldn't be getting.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
