350 build questions
Old Mar 6, 2010 | 08:33 PM
maro305's Avatar
350 build questions
well i have some quenstions on my build, im biulding a 350 small block from ground up with some 85 305 ho heads. i want to stay with the tbi and i was wondering if the intake from my 89 305 will bolt right on to the heads or will i have to modify the intake. i might switch to carb but idk how much of a pain it will be to go to hei from the remote. i dont want anything cobbed on this car i love maros and i like things to look good. thanks guys
Old Mar 6, 2010 | 11:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
'85 heads will require modifying a stock TBI manifold before you can bolt it all down. The center two bolts on each side will be at a different angle on the manifold.
Old Mar 7, 2010 | 07:31 PM
maro305's Avatar
Re: 350 build questions
i just found out going to carb is easier than expected did some research going to carb but will put up more info on build if its ok with everyone. 350 small block time 750 double pumper holley
MustangBeater20
Oct 29, 2022 09:20 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
