Vortec Heads holding me back?
Old Mar 12, 2010 | 01:06 PM
davep_96's Avatar
Car: 1987 Trans Am GTA
Engine: 355
Transmission: TH-700r4
So here's my setup: 355 ci, Vortec heads, Performer RPM intake, Comp 284h cam. Are the Vortec heads holding me back? In other words, if i were to bolt on a set of higher flowing heads(and obviously an intake that goes well with them) would I gain any horsepower? Im just curious that if with my current setup I could be making more horsepower with some better heads.
Thanks,
Dave
Old Mar 12, 2010 | 01:14 PM
Andy316's Avatar
Re: Vortec Heads holding me back?
Vortec heads are good oem heads. You can always make more power with after market heads though. AFR 195 heads on that combo would give you more power.
Old Mar 12, 2010 | 01:22 PM
davep_96's Avatar
Engine: 355
Thanks for the reply man. Yeah the curent setup with the Vortecs is pretty potent but it's tax return time haha. So in your opinion would the AFRs or any other head be worth the swap for the extra power? I dont mind spending the money as long as its not for like 5 more hp
Old Mar 12, 2010 | 01:26 PM
Andy316's Avatar
I dont have them but i like what i read and hear from the AFR 195s. But yes a quality head would give you some more power. If you just go with an economy after market head you probably wont gain that much.
Old Mar 12, 2010 | 01:37 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
any increase in airflow will move your rpm range up at the cost of low rpm torque.
Old Mar 12, 2010 | 06:05 PM
davep_96's Avatar
Engine: 355
My only problems with moving the rpm range up are the limits of the engine and trans. The engine has regular pistons and crank, nothing forged. Also, the 700r4 shifts somewhere in the 5000 range and I don't know how to change it's shift point. I have a 3000rpm stall. What woud be the engine operating range with those heads? Would my engine be ok to rev as high as those heads would want? How would I change the shift point of the trans?
Old Mar 25, 2010 | 12:56 AM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
shift kit.
If it were up to me, I'd stick with the vortecs. They are a respectable head with good flow numbers and CC. Not to mention when you bump the power up you need to think about the strain you'll be putting on existing hardware. Your motor might be freshly rebuilt but your trans prolly isn't and neither is your rear end. Don't wanna blow anything up! :P
Old Mar 28, 2010 | 12:52 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
I'm with Grumbles. As cast AFR's are not going to do much for you; definitely not a wise hp/dollar choice.
Unless you're beyond 400 fwhp right now, stick with the Vortecs.
Old Mar 28, 2010 | 10:10 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Thanks,
Dave
Thats a solid combo man, you should run mid 12's if everything is set up right. Save your money for beefing up your trans/ rear end or use it to buy a set of slicks because you're going to need them!
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
