86 Trans Am making whistling noise?
Old Mar 17, 2010 | 07:33 AM
DHo's Avatar
DHo
Car: 1986 Trans Am
Engine: Vortec V8 5.0L
Hey guys my 305 TPI is making a weird whistling noise, it sounds like it's coming from the front of the engine while it's running, from the belt area. The sound rises in pitch when I rev it. Sounds almost as though the belts are too tight but they don't really feel that way. Can YOU help me?
Old Mar 17, 2010 | 07:53 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: 86 Trans Am making whistling noise?
this can be a few components!! Alternator, Air Pump Water Pump, Tension Pulley, Power Steering
I would investigate the.. Alternator And Power steering first....
Old Mar 17, 2010 | 02:44 PM
DHo's Avatar
DHo
Car: 1986 Trans Am
How would I go about investigating the condition of these components? The alternator was rebuilt, the other things I dunno so I'll have to look at
Old Mar 17, 2010 | 02:51 PM
88gta3508's Avatar
Engine: 231 / 383
you should be able to pin point where the noise is coming from.. turn your wheel side to side.. note any difference... check your PS. Fluid note any difference
you may need a ear scope... to listen
take your serp Belt off.. and check all pulleys for bearing play and rotation drag
Old Mar 17, 2010 | 02:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There is no tension pulley on an '86.
Remove one belt at a time until the noise goes away. That's the component making the noise.
Oh, I recommend shutting off the engine before removing a belt. This ain't a Volkswagen.
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
mizz0313
Aug 12, 2015 06:45 AM
BlackBoulder
Aug 11, 2015 11:15 PM
BrianI
Aug 9, 2015 11:52 AM
