Use narrow band to help tune?
Old Mar 20, 2010 | 11:41 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
I am going to be putting a 1406 Edelbrock on my 1985 305. It already has an oxygen sensor bung in the exhaust up near the manifold so I was thinking about getting an inexpensive gauge from Summit to measure fuel/air mixture. I have read on here that the wide-band is a much better way to go, but I don't feel like spending all that money on a basically stock application.
Is there any benefit to putting a guage on the narrow band O2 sensor to help me fine tune my carb, or should I just tune it by the manual and leave it at that?
Old Mar 20, 2010 | 07:51 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Use narrow band to help tune?
NB is only calibrated to work close to stoich @ 14.7 , once you get away from that AFR the readings are useless as a tuning tool
http://www.innovatemotorsports.com/r...images/n32.jpg
A WB reads accurate from 10 -20
Old Mar 21, 2010 | 08:05 AM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
Wideband is the only way to go!
no green
Jan 9, 2016 09:22 PM
