did i just mess up my steering columb?
Old Mar 21, 2010 | 04:32 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
I was tryign to install a remote starter, to get to the proper wires i removed the 2 13mm nuts and lowered the steering columb.
when i lowered the steering columb i heard a cracking sound. i looked in the engine bay and theres like a brittle plastic/rubber boot that cracked thats part of holding either oil or grease in the steering columb. its jsut after the bolt holding the steering columb to the bar that goes to the gear box.
is this a problem or what? i dont know if i can even replace that boot anymore.
anyone?
Old Mar 21, 2010 | 05:45 PM
Pocket's Avatar
Car: 91 Trans Am
Re: did i just mess up my steering columb?
Not sure how you broke the steering shaft cover, but it cannot be replaced without replacing the shaft. Its a cover to keep anything that may fall on the shaft from wrapping around it. Its not a critical piece unless you have lots of loose wires/hoses laying around the engine bay
Old Mar 21, 2010 | 05:57 PM
Bobby_80s's Avatar
Axle/Gears: no idea
i just unbolted the steering columb to lower it inside so i can get to the wire harness to install a remote starter.
then i hear a cracking noise.
and thats retarted. gm sucks for making it like that. its jsut a stupid cover and if i wana replace it. i gotta replace everything? no thanks.
i appreciate you getting back to me with your info.
the cover is stil there and and still i none piece wrapped around.
once i lifted and re-bolted the steering columb the crack cant even be seen.
and no there is no hanging wires or anything in the way taht could get tangled
Old Mar 21, 2010 | 07:05 PM
Pocket's Avatar
Car: 91 Trans Am
More likely you broke a brake switch for either the tail lights or the cruise. they are directly in the way of the column. The shaft cover is soft plastic and bends quite easily. Unlikely you broke it or head a crunch even if you did
Old Mar 21, 2010 | 07:07 PM
Bobby_80s's Avatar
Axle/Gears: no idea
ill check but i think all those switches are fine.
i saw the crack on the dust cover.
thanks
F-body-fan
Jan 12, 2023 01:49 PM
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
