Hesitation fresh stroker :(
Old Mar 22, 2010 | 04:42 PM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
Im getting hesitation at WOT and when i get over 3k i get a little sputtering and it sounds like little explosions in the headers. Ive messed with the timing, the carb and everything and cant figure this out. Ive checked the valvetrain and re-adjusted the valve lash. I cant find any vacuum leaks and im getting a pretty steady reading of 15 vacuum. Needle bounces a bit but that should be normal because im running a pretty large cam and i have roller rockers.
I rebuilt the carb (600 cfm edelbrock) and the car runs great its just the popping at wot. Only thing i know with the carb is a slightly bent fuel float. So the only other things i can think of to replace is a hotter coil or a bigger carb. Any advice would be appreciated.
Old Mar 22, 2010 | 04:58 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Re: Hesitation fresh stroker :(
I always start with a compression test when troubleshooting.
Old Mar 23, 2010 | 12:50 AM
Engine: 383 Stroker
Transmission: t-56
new engine.. high compression. Anyone else?
Fanatic1074
Oct 3, 2022 05:57 AM
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
JSDaddy189
Sep 26, 2015 03:50 PM
