need help wth main bearings pls
Old Mar 23, 2010 | 10:19 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
i just got my crank back from being polished after my cam wiped out and they told me i needed .001 mains so would that be a .001 under bearing or .001 over.
i would like to use these but im not sure if there correct, any help would be apriciated.
http://www.summitracing.com/parts/FEM-139M1/
Old Mar 23, 2010 | 11:24 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: need help wth main bearings pls
those look like the right bearings. just make sure you plastigage them anyway to be 100% sure. if you get .001-.0015 clearance then the stock bearings would have worked.
Old Mar 24, 2010 | 02:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Bearing are referred to as "under" because the crank journals become smaller when they are ground/turned. Used to be pretty popular in rebuilds, isn't done so much anymore. If the crank is undersize from wear, the typical approach is to turn the journals to 0.010" under.
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
gord327
Oct 3, 2015 01:25 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
mfp189
Sep 27, 2015 09:25 AM
