Comp 1318 roller rockers
Old Mar 24, 2010 | 04:13 PM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Hi,
I bought few weeks ago from foum member set of comp 1318-16 roller rockers.Three rockers have damaged(one flat ridge side of roller tip,maybe hit to valve ????)
Do Summit or Jegs sell those rockers separately?I find only sets at thy web sites.
Old Mar 24, 2010 | 10:01 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Comp 1318 roller rockers
call the manufacturer directly.
Old Mar 25, 2010 | 07:04 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
summit used to sell them individually
but I only found the singles in the ultra pro magnum
http://www.summitracing.com/parts/CCA-1618-1/
Like mentioned before, I would either call summit and ask them or call the manufacturer.
Old Mar 25, 2010 | 08:30 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Comp has a repair service for rockers, and also sells replacement parts to do the repair yourself.
Old Mar 25, 2010 | 12:33 PM
z 28 jari's Avatar
Engine: 385
I mailed to Summit,they don't have separately 1318-1 rockers.They answer:"The replacement is a CCA-1618-1, Ultra Pro Magnum, which are in stock for $20.95 each. There would be no problem running two different rocker arms".
Havet got yet reply from comp cams.
Is welding no-no to rockers?Does it weaken it?
It would be quite easy to make new ridge to rocker.
Old Mar 25, 2010 | 01:56 PM
3rdgenmaro's Avatar
Car: 88 IROC
I definately would not weld on it. They see a ton of abuse. CALL comp and talk to them, that will get you an answer quicker. If they cant do anything, then just get an ulta pro magnum to replace it. But im sure comp will help you out.
Old Apr 9, 2010 | 02:45 PM
z 28 jari's Avatar
Engine: 385
Got today three new rockers(pro magnum).Only minus was total cost of 3 rockers.After tax,shipping and etc. I paid 120$...And this was very cheap if compare to comp cams shipping fee which was ~120$ to three rockers when I asked.
When you bought good and cheap you propably bougth two separate items...
no green
Jan 9, 2016 09:22 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
