oil pressure switch location and swap?
Old Mar 26, 2010 | 12:13 PM
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
I have an 87 firebird, the gauge reads around 40ish sometimes but sometimes it's slowly dropped, trying to figure out if it's the oil pump or the pressure switch. Someone told me if my oil pressure was actually dropping like the gauge suggested i would instantly hear the lifters knocking...
Regardless it's old, been sitting for years and i'm fixing it up.
Where is the switch located? and is this an easy swap?
Old Mar 26, 2010 | 01:18 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Sending Information.
The oil sensor sender is located in the lower left side of the engine.
You might need an oil sensor socket depending if it’s original or aftermarket.
That will become obvious when you see the sender.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
ChevyZ71
Aug 13, 2015 07:30 AM
92camaroJoe
Aug 13, 2015 06:07 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
