Has Anyone Built a V6?
Old Mar 26, 2010 | 06:07 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Seems like everyone is wanting to build a V8. since I'm building my T/A for auto crossing I don't think I'm going to need 500 hp under the hood.
Many V6 engines since the early 90's easily have 200 hp. So I'm thinking of building a V6 and getting it into the 300 hp range. Any suggestions for a good cheap build?
Old Mar 26, 2010 | 07:00 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Has Anyone Built a V6?
The later model Vortec 4.3 liter V6 is a good cheap one (late 1990's & up).
I build them.
Basically stock gives around 200 hp. Built is anywhere from 250 to 300 hp depending on specs. They are very similar to the Chevy 350 engine and the heads have the excellent design that performs extremely well will modified with porting and valve upgrades like the LSX valve conversion in my signature. I build the later model 4.3 heads often and I like them.
Intakes are available for carburetion, TBI, or MPFI.
Good quality exhaust headers are available. Stainless versions from Gibson are the best I've seen.
The 4.3 uses the same water-pump as the SBC1 V8, so the cooling system is over-designed for the size of engine. You have to really mess something up to have a cooling problem with a 4.3L. It can also use the SBC1 V8 pulleys, easily found at swap meets.
The 4.3 shares many parts and similarities with the SBC1 V8, but I can't remember them all right now.
They make good engines for small/light trucks. They are very torquey.
They are not as light-weight as an aluminum LSX style engine, nor do they take the high RPM as well.
The later model 4.3L crankshafts for them are split-pin design which is generally considered to be weaker and not trustworthy at higher RPM. The stock rods & pistons are relatively heavy as well - not a problem for a truck engine. You can upgrade them, but then it's not cheap anymore. The high air-flow capability of the heads combined with a relatively RPM limited bottom end make it a perfect candidate for a power adder. A power adder like N2O would keep it cheap. Polish the tops of the stock cast pistons and they will be fine to over 100 shot of N2O barring any detonation.
The later model 4.3L is set up for the standard GM hydraulic roller lifters, but also uses a balance shaft in the lifter valley. The balance shaft can stay or go, but if you delete it don't forget to plug the oil-feed to the bearing.
Old Mar 26, 2010 | 07:14 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
built V6's are fun.. lots of ways to get great power out of them.
The number one advantage is weight, my 320 HP 3.5 V6 weighs about 300 lbs less than a SBC.
Old Mar 26, 2010 | 07:16 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
seems like it would cost more money...no? as to just getting an LS engine swap...
Car: 1986 Trans Am
Engine: 5.0
But what is the preferred engine? I'm thinking aluminum
Old Mar 26, 2010 | 07:35 PM
Engine: 450HP 355
Transmission: TH350
I used a '04 3500 V6 from a Malibu. The heads flow amazing stock and with some port work can really do well. I gained about 120 HP over stock with porting, a cam and headers. It's an iron block with an aluminum top end. weighs around 350 lbs dressed.
Check out www.60degreev6.com and www.wot-tech.com for parts.
This engine with a 5 speed ran a 13.07 in a 2800 lb car, trapping around 110 mph. I could never get traction which is why it's going in my Camaro in place of the 327 that came with it.
LSx swap is also a good idea, it's very light and responds extremely well to mods.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
6998poncho
Sep 25, 2015 02:56 PM
