350 Miniram AFR Combo
Old Mar 30, 2010 | 05:36 PM
TMFK's Avatar
Car: 85 Z28
Engine: ZZ-3,Mini-Ram, Holley EFI
Transmission: 700-R4
Axle/Gears: Hawks 8.8
So, here's my plan:
ZZ-3 short block w forged flatops (already have)
Miniram (already have)
30 lb injectors
AFR 195's pn 1040 w/upgraded valve springs
Comp cams 280 xfi
pro mag lifters
ultra pro mag 1.6s
Trick flow hardened push rods (already have)
I'll have to run the oem 85 ecu still, for now, which sucks ***** i know.
I plan to get dfi in future. Its very common parts, but it should make good power (430ish) maybe more when tuned.Its in a 85 Z28 street/strip.
Anyone else running the same combo? Any yeas or nays?? Thanks for your help!!!!!
Old Mar 30, 2010 | 06:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like a potent combo, but I'd guess the '85 ECM is going to hold you back.
LT1Formula
20
Nov 14, 2015 12:02 AM
Magman
Sep 12, 2015 10:43 PM
Eric-86sc
Aug 24, 2015 09:01 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
