Help with fuel fittings and hose for aftermarket intake
Old Apr 5, 2010 | 04:46 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
Little confused here. I bought a FIRST TPI intake that has 3/8" NPT fuel rail fittings. Adjustable fuel pressure regulator (below) I'll be ordering also has 3'8" NPT fittings.
http://www.summitracing.com/parts/AEI-13301/
Most of fittings and hoses I see (Jegs, Summit) are AN sizes. Jegs does have a few fittings and hoses in 3/8" NPT size that I'm thinking of getting.
http://www.jegs.com/p/JEGS/JEGS-NPT-...63082/10002/-1
Will I be ok with these or should I get NPT to AN adapters and AN hosing? Also I'm assuming the stock fuel line to regulator is not 3/8". Does anybody know what size it is? I'm thinking I'll need an adapter to connect stock fuel line to Aeromotive AFPR. Thanks!
Old Apr 5, 2010 | 05:10 PM
Twin_Turbo's Avatar
Re: Help with fuel fittings and hose for aftermarket intake
use npt to an adapters and then an hose ends and hose.
There are fittings available for the stock lines, they are 16 and 14mm x1.5 O ring
Old Apr 28, 2010 | 07:02 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Thanks for the info. Helped start to locate what parts I need. Hardest part is figuring what parts you need and then ordering them!
Old Apr 28, 2010 | 07:22 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Pure choice should have what ya need. I got a ki from them for my lt1 fuel line setup. Top quality. Good price , etc..
http://www.purechoicemotorsports.com...cat/cat133.htm
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
