new motor, car either backfires threw exhaust or tb
Old Apr 7, 2010 | 08:42 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Got the new motor in and it wont run. It seems like its trying to start but then it backfires like a shotgun. At first we got it close to 6deg advanced with a light but when when my buddy started adjusting the dizzy it would either pop out of the throttle body or backfire really loud. Could mis-adjusted valves or a bad vacuum leak cause these problems?
Old Apr 7, 2010 | 09:03 PM
bcmag's Avatar
Re: new motor, car either backfires threw exhaust or tb
could be misadjusted valves but sounds more like dist. is in wrong or firing order isnt right.
Old Apr 7, 2010 | 09:45 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Is it 180 out? Like said above it could be too tight on the valve lash. Plug wires could also be crossed. Is is it a 4-7 swap cam?
Old Apr 7, 2010 | 09:55 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
The distributor shows 3 deg advanced right now with the timing light so I cant see how its off if the #1 spark is being thrown in accordance with the harmonic balancer timing marks.
Old Apr 7, 2010 | 11:03 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
That being the case I'd try running the valves again but first turn it 180 just to see what happens. It's easy to do and less time consuming than relashing all the valves. Why not try it just to see?
Old Apr 8, 2010 | 08:04 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Im going to relash the valves and if that doesnt do it I might have to take the Superram intake off and buy a new set of gaskets........ theres probally an intake leak,, that intake was a PITA like no other to install for the first time.
Old Apr 8, 2010 | 08:12 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
whats a 4-7 cam? Its comps 276 hr114
Old Apr 8, 2010 | 10:17 AM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
It's a cam that changes the firing order. The numbers 4 and 7 are swapped. Instead of 18436572 it's 18736542.
Old Apr 8, 2010 | 10:29 AM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
sounds like the dist; is 180 off or the cam itself is
Old Apr 8, 2010 | 04:32 PM
bonesbrakr's Avatar
the distributor is 180 out. The harmonic balancer is at TDC for the compression stroke and the exhaust stroke thats why it lines up with the light.
Old Apr 8, 2010 | 05:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Come on, guys, it wouldn't run at all if the distributor was 180 degrees off.
Old Apr 8, 2010 | 08:28 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
You should re-read his first post. He does state that it won't run at all.
Old Apr 9, 2010 | 09:16 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
My friends have been saying it must be really off or 180 from the start, Ill try it and see what happens.... thanks for all the help thus far.
Old Apr 9, 2010 | 09:29 AM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
It seems like it's gotta be that. It's worth a shot and won't take very long.
Old Apr 9, 2010 | 12:14 PM
Guest
Guest
Posts: n/a
Old Apr 9, 2010 | 12:33 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
I agree as well
Old Apr 9, 2010 | 01:01 PM
five7kid's Avatar
The video has the car running.
Old Apr 9, 2010 | 01:07 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I thought that was just his sig with the old motor. Care to clarify?
Old Apr 9, 2010 | 01:25 PM
Guest
Guest
Posts: n/a
Yea, that video is in his sig. He says at least 3 times in his original post the car does not run. I'd say it doesnt run.
Old Apr 9, 2010 | 06:19 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
That is correct. It does NOT run. The video is the car running with the old 350 in it(which turned out to have 3 broken pistons). The new 385 is what I have in the car now.
Old Apr 10, 2010 | 12:05 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Dizzy was 180, shes running now but the superram has a massive intake leak,,,,, Im going to order a new gasket kit and now that I have some experience putting the intake together Im confident itll be leak free this time
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
1nastygta
Aug 8, 2015 07:38 PM
