Iac Housing ?
Old Apr 7, 2010 | 09:01 PM
Hesstrck26's Avatar
Car: 1988 iroc z hard top/04 fast cummin
Engine: 5.7 350
Transmission: built 700r4
Axle/Gears: 2.77
Iac Housing ?
Have been having high idle problems with a 88 5.7 tpi camaro. Bought new iac and housing from tpis. Installed and now idles even higher. Question is in putting on the new housing it only uses 3 bolts, could air be pulled from some of the open holes in the bottom of the tb? tried to set minimum air as per everyone here w/ no luck. Cant get idle in drive to fall under 900 rpm. any advice would be great as i am willing to try anything i havent already tried. Thanks, Jason
Old Apr 8, 2010 | 05:43 PM
Hesstrck26's Avatar
Engine: 5.7 350
Axle/Gears: 2.77
Re: Iac Housing ?
anyone ?
Old Apr 9, 2010 | 04:37 PM
Camarillo's Avatar
Car: 1990 RS Camaro
Engine: 1990 305 tbi lo3
Re: Iac Housing ?
Does your IAC have an adjustable pintle? as per the manual, my 90 305 tbi has IAC legnth requirement of less than 1 and 1/8'' from flat edge to tip...
Old Apr 9, 2010 | 09:10 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Re: Iac Housing ?
That's how long it should be when
you install it any longer and you may
strip it
Old Apr 12, 2010 | 03:38 PM
Hesstrck26's Avatar
Engine: 5.7 350
Axle/Gears: 2.77
Re: Iac Housing ?
Ya read all abt setting length did that and still no luck so i took it back out put it in a bag and connected it nothing happened. returned the cheap part bought the more expensive one and presto she is purring like a kitten. bought a bad part, not the first time this has happened hopefully its the last. Thanks for the advice.
thejimsterz28
Sep 30, 2015 08:52 PM
