timing question
Old Apr 9, 2010 | 02:16 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
timing question
i know the basic method of adjusting my timing, but i am curious if the timing (as read on the pointer thing) is even correct.
is there a way to check this without pulling a head and checking for TDC?
the reason i ask is because i would like to button down the timing for sure.
this all started when i discovered that i had a hole in the distributor cap from one of the screws that held the rotor on flying off...
i fixed the rotor, and put the distributor back where i thought it should be (based on marks on the firewall and rotor, but now the car feels a lot more sluggish.
so i advanced the timing some (but forgot to check where it was before i messed with it and also forgot to unplug the brown wire)
now i think my timing is all messed up.
before, even with the screw missing from the rotor, i needed premium to keep from having severe detonation
now i can run regular with no trouble and the car feels noticably slower below 2500 rpms and requires more pedal to "get up and go"
once i get to about 3000 it picks up some, but still feels like its less than before
Old Apr 9, 2010 | 02:26 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: timing question
Didn't we already do a thread on you an advance curve?
Okay, if you want to start from zero, you'll need a piston stop that screws in through the spark plug hole, and you'll need to pull your accessories to put a drgree wheel on your crank. from there you can figure out where true TDC is, then remove the piston stop, put the engine at TDC, (#1 cyl) and remove the degree wheel. then clean your damper and put a new timing tape on it, then put the accessories back on.
Old Apr 10, 2010 | 09:50 AM
Car: 85 Camaro IROC
Engine: 5.7 TPI
Re: timing question
not that i know of, but im pretty forgetful.
ok.
i was hoping there was a way to tell from the valves or something.
as for getting my timing right, if i understand correctly, the tan wire controls the electronic advance, so if i advance the timing with the distributor, all i am really doing is fooling the computer... right?
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
