Valve adjustment
Old Apr 13, 2010 | 11:48 PM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
Valve adjustment
Im really curious and hear mixed answers. When adjusting valves, which is best or is it the same?
Adjust some of the valves on tcd of #1 and the rest on #6
OR
Adjust them one at a time on the compresson stroke.
I like the first way best because i know for a fact when each is on tdc because of the mark, but doing them individually i cant really tell. Like when i move from #1 valve to #8, the rockers never move, so i cant really when its on tdc.
Does anyone know?
Old Apr 14, 2010 | 06:34 AM
game1939's Avatar
Car: 91 chevy camaro
Engine: 383
Transmission: 700r4 built with corvette servo
Axle/Gears: posi 3:73
Re: Valve adjustment
Here are step by step instructions:
  1. Remove the valve cover.
  2. Identify the number one cylinder. Turn the engine over until you see the number one cylinder exhaust valve rocker arm JUST START to move from the closed position to open. You may need to turn the motor over a couple of times to reach this point, but do not turn any further.
  3. Locate the intake valve.
  4. Loosen the rocker arm adjustment nut until you feel some obvious lash or clearance in the adjustment.
  5. Using the thumb and index finger of one hand, grasp the intake push rod below the rocker arm, and rotate it back and forth (clock-wise and counter clock-wise successively to be sure there is no remaining pressure on the push rod from the rocker arm as you loosen the rocker arm adjusting nut.
  6. Using the other hand, while continuously performing step 6, with a 5/8 socket and ratchet, tighten the rocker arm adjustment nut slowly until you feel a resistance of motion on the push rod.
  7. This will be the zero lash adjustment point. For hydraulic lifters, tighten the rocker arm adjustment nut 3/4 of a turn. For solid lifters, back off the rocker arm adjustment nut until your feeler gauge just fits under the contact point between the valve stem and the rocker arm. Fine tune the adjustment by checking it with a feeler gauge just slightly thicker than the preferred clearance to be sure the clearance is not greater than it should be. If the larger feeler gauge will fit, it needs to be re-adjusted. A lash tolerance of 1-2 thousandths of an inch in the valve adjustment for solid lifters would be acceptable since it may be difficult for someone who is in-experienced to be more precise than that.
  8. Turn the engine over until the intake valve opens and then is almost closed.
  9. On the exhaust valve, repeat steps 5 through 8 for the exhaust valve adjustment.
  10. Repeat this procedure for each cylinder. Be sure to do each cylinder sequentially, either following the firing order, following the cylinders numerically, or in the case of a V8 doing one side of the engine at a time. I prefer to do one side of the engine at a time.
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
dimented24x7
Sep 6, 2015 03:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
