Unknown Sensor connector.
Old Apr 16, 2010 | 09:53 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
i GOT A 91 FIREBIRD TBI.
I was looking around for for any loose connections; I came upon this wire It's (TAN and BLACK) I didn't find anything unplugged. It's on the left side of the TBI. I really dont know what it's for. i know it must be for something because if it wasn't then it wouldn't be there. Does anyone have an idea what it could be for?
Old Apr 16, 2010 | 10:04 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
Re: Unknown Sensor connector.
looks like a piggtail for the ignition coil or the manifold air temp sensor more likely manifold air temp sensor
Old Apr 17, 2010 | 08:46 AM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
manifold air temp sensor might be correct but my manifold does not have that sensor in it; nor the hole for the sensor. I am getting a error code 23 for the "manifold air cold" mine only has the vacuum sensor. What do i need to replace it?
mine has this air sensor
Old Apr 17, 2010 | 11:11 AM
juanillox8's Avatar
Car: TOO MANY
this (links) is the MANIFOLD air temp sensor aka air charge temp sensor im sure its the one you need
http://cgi.ebay.com/ebaymotors/90-91...ht_9119wt_1165
http://www.rockauto.com/catalog/rafr...251739k1984766
Old Apr 17, 2010 | 12:58 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
So do i just drill a hole in the manifold and pop the sensor in?
Old Apr 17, 2010 | 02:05 PM
j4petro's Avatar
Car: 1987 IROC Z
Engine: 5.7 TPI
Axle/Gears: Borg Warner 3.27
That same plug connected to the MAT sensor under my TPI plenum near the rear in front of the distributor. It was a 12 inch pigtail the connected to the main harness.
Old Apr 17, 2010 | 02:19 PM
bcmag's Avatar
follow al intake runners visually.i dont know on yours for sure but usually they are either located there or on air cleaner assy.definitely think its mat sensor harness.
Old Apr 17, 2010 | 02:40 PM
Camarillo's Avatar
Car: 1990 RS Camaro
Engine: 1990 305 tbi lo3
Definitely looks like the mat sensor plug. Is there a mat sensor in you AIR CLEANER HOUSING? Mine is located behind tbi (on bottom of cleaner housing, between air filter and tbi system). The the sensor you pictured is the one that helps control the thermac thing, in the snorkel.
If you dont have this sensor there(mat), perhaps the air cleaner housing is not original. I purposely went out and unplugged mine, and it set the CODE 23 as well.
If really no other sensor in your cleaner housing, check local junk yards, or drill the proper sized hole in the BOTTOM of the AIR CLEANER housing
I have a 1990 TBI Camaro.
Old Apr 17, 2010 | 03:22 PM
Trick414's Avatar
Car: 1991 RS Vert
Engine: LO3, 305, TBI
Definitely MAT sensor plug.
Old Apr 17, 2010 | 03:42 PM
juanillox8's Avatar
Car: TOO MANY
not in the manifold!!!! as stated avobe do it in the air cleaner housing
Old Apr 17, 2010 | 03:44 PM
juanillox8's Avatar
Car: TOO MANY
VERY NICE!!!! this forum need more people like this, willing to get off the couch take their camera and take some pictures to help the crowd here...
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
efiguy
Sep 27, 2015 01:30 PM
