whats it worth?
Old Apr 19, 2010 | 08:13 AM
greatskiiiier's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: 12 bolt/ 4.11
whats it worth?
doing a sbc build and about 2/3 the way done and figured id see if i spent my money wisely, so whats this worth? ill post how much ive spent after i get some feedback...
4 bolt main bored to 4.060, decked .020, all machine work done
reground stock crank
glass blasted and magnafluxed forged rods
keith black silv-o-lite pistons
arp main studs
arp rod bolts
vortec heads with all machine work done for the high lift springs, screw in studs, guide plates, and minor port n polish (bowl blend, unshrouded chamber, cleaned up runners, minor pocket porting)
comp .490/.490 230/236 cam n lifters
HEI 50,000 volt distributor
Weiland Stealth intake
650-750 carb, not sure yet
all name brand parts went into the rebuild, almost no bolts were reused, and everything that was needed to be replaced was, and everything was reconditioned
also got a turbo 400 that im including in my "overall budget" that ive spent
Old Apr 19, 2010 | 08:20 AM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Re: whats it worth?
You might get $1500 on it if you have the receipts and it hasn't been used yet. Engines haven't been going for much recently, I have a 468 small block with a super ram on it and haven't been able to get rid of it for 1/4 of what I spent on it. If you do get $1500, consider yourself really lucky.
Old May 9, 2010 | 10:36 AM
Car: 98 z28
Engine: ls1
Transmission: t56
Re: whats it worth?
anyone else? also any guesses on how much power itll make?
Old May 9, 2010 | 05:27 PM
CrackerJack87's Avatar
Car: 87 z28
Engine: 355/Edelbrock Heads/Pro-Flo Inj
Transmission: Monster 700r4(500hp)9.5" 2800 stall
Axle/Gears: 10 Bolt with 3.23 posi
Re: whats it worth?
Id say anywhere between 360-420 HP at the flywheel depending on your induction.
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
6998poncho
Sep 25, 2015 02:56 PM
