Excessive Fuel Consumption
Old Apr 21, 2010 | 10:31 PM
DHo's Avatar
DHo
Car: 1986 Trans Am
Engine: Vortec V8 5.0L
Hi there I've got an 86 Trans Am 5.0L.. it's having a problem of using an insane amount of fuel.. last full tank only lasted about 160km. It definitely smells rich. I used a paperclip to pull the codes.. I came up with a 44, which corresponds to low voltage to the O2 sensor? I went to try and find it but my car doesn't seem to have one (?) the only thing similar is a sensor that looks like it's coming from the right (from the front) exhaust manifold, I can get at it from the engine bay but haven't taken it out. Additionally, the coolant and oil pressure gauges aren't working.. the oil pressure one sometimes reads a tiny bit but not much, and usually doesn't read anything. Could any of these things be the problem? If anyone can tell me some basic tests to run, that would be great.. thanks.
Old Apr 21, 2010 | 11:40 PM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: Excessive Fuel Consumption
02 sensor would be on the drivers side exhaust manifold, there should be one wire coming out of it with a pig tail about 9inches away. replace it
Old Apr 22, 2010 | 12:00 AM
Gregzz4's Avatar
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
DUDE!!!
You said..
Additionally, the Coolant and Oil gauges don't work.
That's no way to treat a Third Gen.
How do you know if it's low on Oil or Overheating ??
Sorry, but that's Driver Abuse
Bad You
Old Apr 22, 2010 | 12:09 AM
Gregzz4's Avatar
I know this has not much to do with your post, but you should fix your car
Ok, maybe you need some new sensors
Maybe you could spend some money and get an Oil sensor from a parts store, or, preferably from GM. That may solve your bad Gauge issue.
Hopefully it's not bearings.
The Coolant issue may be very simple or complicated.
If I owned your car, I would make sure the coolant is full. Then I would source a new sender for the dash gauge...prefer from GM....and if that didn't fix it then I'd go to a garage as there are too many more things to tell you.
Old Apr 22, 2010 | 06:20 AM
DHo's Avatar
DHo
Car: 1986 Trans Am
Johnny- ok thanks that's what I thought it was..
Greggz- I know I gotta get on those two things.. for the time being yeah I gotta check the oil and coolant each time I drive. Them not working is why I posted LoL and you didn't really give me any advice. Where do I get to those two sensors and how can I test them? Voltage? Or resistance?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
beachrodder
Aug 25, 2015 08:05 AM
86IROC112
Aug 21, 2015 07:20 PM
92camaroJoe
Aug 13, 2015 06:07 AM
